Excel Formula and Defining a name.
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi.
I would like to know, if I had a cell that had a name defined to it, so "SavingsMoney"
Is there a formula I can use, that will find any cells within a range that is using "SavingsMoney" e.g. "=SUM(SavingsMoney)", and then add all of them together, so say if savings money was set to £50 and I put the =SUM formula in 3 boxes, I'd want the specific box that adds all of them up to show £150.
Thanks.
You could always try it?
But from memory if the defined named range is a continuous range then yes (as it is just treated as a 1d array) if not then no as even a cell is a range and you cannot have 2 ranges with the same name.
I don't think you can do that. Certainly not straightforwardly.
(If "SavingsMoney" is a single cell then
"=SavingsMoney" is a bit easier than "=SUM(SavingsMoney)")
If this is a one-off requirement then how about using Find&Replace to replace all instances of "SavingsMoney" with "SavingsMoney". That will tell you how many there are.
If this is an ongoing need then it would be possible to write a UserDefinedFunction to do what you want. There may also be add-ons out there that would help.
