Excel Formula Date adding help please
18 Oct 2002
Earth
I'm trying to work out how i get a Formula to work and hoping someone here wil be able to help me please.
What i need is when i put a date in the C column 01/01/2009 in column D it gives me the result by adding 150 days.
So the result would show in D column 31/05/2009.
I used this =C2:C100+150
But as soon as i put say 04/04/2009 in C3 i don't get a result in D3?
Is there a way i can set what every i put in C column i get the result in D column? Instead of having to allocate that Formula to each cell in the D column.
I just can't work it out :(
Thanks.
Change the D2 formula to =C2+150
Select D2, then drag the cell down from the bottom right corner to however many rows you need.
