Excel formula help
18 Oct 2002
Maidenhead
Hi all
Ive got about 500 entries and need to search each cell in a column for the string "MF" (could be uppercase or lowercase) within each cell.
A selection example would be:
eb0l29
eb3l29
eb4mf57
eb5l72
FE2L4
MG0MF31
FLIL30
FN0IN48
FW1L53
FW2I39
I would therefore need the formula to pick out eb4mf57 and MG0MF31 from the above list
Not using a formula here, but it might be useful to you.
Select the whole column
Click 'Edit' -> 'Find'
In the 'Find What' box type 'mf'
Click 'Options'
Change the 'Look In' drop down to use 'Values'
Use 'Find All' or 'Find Next' to see which cells contain those values.
=NOT(ISERR(FIND("MF",UPPER(cell you want to check))))
This will return TRUE for any cells containing MF (case insensitive) and FALSE for any others.
Thanks. Used
=IF((SEARCH("mf",B2,1))=4, "Yes", "No")
Haircut, can you explain how yours works?
looks like your will return a "yes" whenever "mf" is found at precisely the 4th character. Haircut's will return a "true" if "mf" is found anywhere in the cell.
