excel formula help
11 Oct 2005
Derbyshire
Hi, cannot seem to get my head round the following. perhaps some one can help with the formula for Excel.
here is what i want
basically. in what cell time you arrive at work. another cell time you leave work. then a way of adding those cells up.
eg:
A1........................B1................C1
Start Time........Finish Time.....Total Hours
8.30am...............3.30pm...........7 hours
Thank you people :)
I'm not saying this is the neatest way but this will convert the text time in cell A1 to a decimal time:
Code:
=(LEFT(A1,FIND(".",A1)-1) + IFERROR(IF(FIND("pm",A1)>0,12,0),0))+(MID(A1,FIND(".",A1)+1,2))/60
just copy that to cell d1 (which will than covert the text time in cell b1) then d1-c1 gives you your total hours. Will work providing the times are entered as x.xx[am/pm]
eg:
If you're entering these times manually you could simply use a time format that Excel recognizes (such as hh:mm) then use the formula joeyjojo gave.
Just set the format as time HH:MM:SS (under the time category) for the input boxes and [H]:mm:ss for the output box and do the equation Joey said.
Job done if you want the results in hours and minutes.
