- 18 Apr 2004
- Milton Keynes, UK
I have the logic in my head though I can't work out if it's best to go in rows or columns. I've tried both and it adds all.
So I'm trying to count simply what days staff has done overtime working out if it's weekdays or a weekend. I'm using the following format from M3 onwards
Sat | Sun | Mon | Tue | Wed | Sat...
03-Sep | 04-Sep | 05-Sep | 06-Sep | 07-Sep | 10-Sep...
Hours | Hours...
I just enter the number of hours worked in the hour cell. I only want to count up the number of weekdays worked and then the number of weekends worked.
Formula is =IF(AND(M5 > 0,OR(M$3="Sat",M$3="Sun")),COUNTA(M5:BY5),0). But this adds up all cells regardless if it's a weekday or weekend. Do I need to use a loop to work out if it's a particular day of the week AND if it has a number, then add to a list/array and repeat? I'm not sure if it needs to be as complex as it's making out.
Hours | Hours...
