Excel formula/macro
28 Dec 2003
Aberwristwatch
Hi. I need a macro to do the following;
Column A is the area code which all address records are sorted by. When this code changes to the next area, I need to insert a row to divide it from the next area and insert *** (three stars) as a visual indication of the change.
A B C
1 abc abc
1 abc abc
1 abc abc
2 abc abc
Something like:
Code:
Sub SplitAddressCodes()
Dim RowsToCheck, i
Dim strAddressCode, strAddressCodeNext
RowsToCheck = 34 ' Put how many rows you have here or put a Do Until strAddressCodeNext = "" instead of For
For i = 1 To RowsToCheck
    strAddressCode = Range("A" & i)
    strAddressCodeNext = Range("A" & i + 1)
    If strAddressCodeNext <> strAddressCode Then
        Range("A" & i + 1).Select
        Selection.Insert Shift:=xlDown
       Selection.Value = "***"
        ' Add an extra
        RowsToCheck = RowsToCheck + 1
        i = i + 1
    End If
Next i
End Sub
Hi
Thanks for that. Very nearly. The code seems not to add an extra row, just inserts stars into the cell beneath
The spreadsheet is to be mail-merged and I want a sheet with *** in the address lines seperating every Selection Code (column C)
DOH! I was being dense. It's inserting a cell into the specific column not the entire row.
Code:
Dim RowsToCheck, i
RowsToCheck = 30 ' Put how many rows you have here or put a Do Until strAddressCodeNext = "" instead of For
        Rows(i + 1).Select
        ' Add an extra
        i = i + 1
    End If
Next i
End Sub
