Excel Formula Question
21 Mar 2004
Dorset
One for the bright boys out there.
I've got a timesheet programme in EXCEL that adds up all my hours worked in hours and minutes giving me a total for the week of say 39hrs 42mins.
I want to display that total in another cell as a decimal ie 39.7hrs. Is there an easy way of doing that???
Hope this questions ok in this forum. If not mods are welcome to move/delete.
They are in the format xx:yy ie the cell is formatted to display hh:mm.
I want to display the time period as a decimal in a seperate cell.
To convert a time less than 24hrs to decimal:
=(??-INT(??))*24
where ?? is the cell containing the original total
To sum a range of times to a decimal:
=SUM(range)*24 format as 'general'
Thanks Nelson that works a treat. I just need to try and understand how now................................
My initial elation was premature. This only works if the total hours and minutes is less than 24!
I need to be able to convert 225hrs 45mins (displayed as 225:45) into 225.75hrs (displayed as 225.75). I've tried googling but can't find anything I can make work.
I think it all depends on what FORMAT each cell is?!?!
For example if I make A1 (Format - Cells - Custom - [h]:mm:ss) then I can enter a "time" greater than 24hrs. This "time" is ACTUALLY STORED as a DATE but displayed as a TIME.
If I make B1 (Format - Cells - General), then I can represent that DATE/TIME as a decimal number, simply by multiplying by 60.
eg:
A1 - type in 225:45 (gets displayed as 225:45:00, but is actually stored as 09/01/1900 09:45:00)
B1 - type in =A1*60 (gets displayed as 225.75)
Which seems to do what you want?!?!
But it really depends on what FORMAT your "numbers/time/dates" are actually using.
=MID(TEXT(A1, "[h]""hrs"" mm""mins"""), 1, FIND("hrs", TEXT(A1, "[h]""hrs"" mm""mins"""))-1) + MINUTE(A1)/60
With the time value to be formatted in A1
The problem is that Excel is storing the time differently to how you have chosen to display it. It always seems to treat it as a time on the 24 hour clock even if you use [h] to force it to display a number of hours > 23.
Whilst it is displayed this way, you can't use the data in this way. The formula above basically returns the formatted value as a text string that can then be manipulated. Its not particularly pretty but I think it is the only way to do it.
Ric.
lol that is completely unnessecary what I just did. Aslong as you store it as a time then:
=INT(TEXT(A1, "[h]"))+MINUTE(A1)/60
will achieve what you want
Thanks Ric this appears to work fine. I'll do some more testing when I get back to the office tomorrow!
