Excel / Google Sheets 'SUM' repeating help please :)
5 Mar 2003
Swadlincote
I've got a google sheets spreadsheet which i have multiple 'sums' on it. How can i repeat those sums down the columns without it filing in Zero's all the way down? If i don't 'drag' the formula down (and get all the zeros!) it means having to individually drag down the 'sum' on every cell i populate and there are about 12 columns worth of numbers.
Basically, i only want the sum to appear when i have filled that particular cell and not show gobbledygook or a zero beforehand.
I'm sure there must be an easy answer to this and i hope my question makes sense.
Any help appreciated. Thank you.
Change the cell format to hide zeros or change the formula to check the contents of the cells you are summing first ie =if(a1="","",sum(a1:d1))
No, i've got in a pickle with that. So here is the first sum and i want to bring that down to Row 9,10, 11 etc etc and not show anything if the value is zero . =SUM(D8-B8)
=IF(SUM(D8-B8)=0,"",SUM(D8-B8))
although if you really are doing SUM(D8-B8) then you don't actually need the SUM function
=D8-B8 gives the same result as =SUM(D8-B8)
