Excel help, can it even do this?
23 Dec 2002
Shiny Shanghai
Hi all
I tried to find the answer to this to no avail.
Does anyone know if this is possible?
Basically, I want to put an X in the cell in column C if the cell in column I is highlighted green and then just copy paste all the way down column C.
Sounds simple?
Any help? :)
If this is a one-off, Filter by colour, then add a column with a value per colour.
Your formula can use that value as part of the IF statement.
That stackoverlow looks promising.
A little convoluted, but might save time down the line. :)
I'll give it a whirl later. Also potentially the skyripper suggestion too !!
Solved quite easily.
Here's the solution. :D
I was using conditional formatting to highlight the duplicates in column I using..... =COUNTIF(I:I,I1)>1
So then instead of doing another formula to detect the highlighting, someone suggested to forget the conditional formatting in column I and just go straight for column C with.... =IF(COUNTIF(I:I,I1)>1,"X","")
Did the trick nicely :D
Only problem is that once the duplicates are removed, the Xs also go, so I need to copy and 'paste special' them. No biggie !!
Yes, but I don't want them removing.
Well.... not straight away.....
It's hard to explain :D
I used conditional formatting to do this the other way around last week, whereby if cell A1 = "Saturday" then colour grey. I can't remember the code off hand. So as said above, conditional formatting in reverse.
