Excel help - displaying number as a month
18 Oct 2002
Brighton
Is there any easy way of displaying a number as a month without using a long IF formula?
For example, if the value of a cell is "11", how can I get excel to display it as "November"?
The MONTH function seems to display "11" as "January" (it appears to think that it's the 11th day, not the 11th month.
Cheers.
I can't seem to create a working custom date option - it always reverts to believing the number is the day rather than the month.
If memory serves me correct: and I will be vauge here!
You need to create a custom list ???
Look up custom lists
As I said Im not sure, but it seems to ring a bell. Its been a long time!!
Rik
Thanks but managed to do it another way:
A1="11" (for example)
=DATE(2000,A1,1) returns the date "1st November, 2000"
Format that as "mmmm" displays simply "November"
