Excel Help for a Numpty!
6 Mar 2018
Weston-super-Mare
Hi All, I thought I was reasonably ok with using Excel, but have a total mental block with this seemingly simple issue!
I'm using Excel to calculate the percentage of a certain gas in a mixed gas input into a chamber.
So when inputting 10 Standard Litres per Min (SLPM) using a 5% to 95% gas mix. The 5% quantitiy in Standard Cubic Centimeters Meters (SCCM) can be calculated by using this Excel command
"=SUM(A2*1000/100)*5".
Now all I want to do is write a command line that will calculate how much I need to increase the 95% gas flow, to reduce the 5% gas flow to a 3% ratio mix.
I know that the answer to this is that the flow needs to increase to 16666 SCCM, but dont know how to write the Excel command?
Thanks in advance.
Perhaps i'm being stupid (very likely), but if you're reducing the 5% element down to 3%. Would the 95% not just increase to 97%?
Also if you're reducing from 5% to 3% would the SCCM not reduce?
Many thanks for your response. There's some info I should have included. The 5/95% gas mix is fixed and I need to add an additional gas to reduce the ratio. So, using an Excel formula I'd like to calculate the addional gas required from a separate gas line.
If you are adding a second 100% gas at flow rate Y then the percentage in the mix is given by:
%age = (10 * 0.95) + Y)/ (10+Y)
So to get 97%
0.97 = (9.5 + Y) / (10 + Y)
9.7 + 0.97 x Y = 9.5 + Y
0.2 = 0.03 x Y
Y = 6.6666666
