Excel Help needed
5 Aug 2006
right firstly I'm not totally sure this is the right area but hell seems close enough
secondly I'm useless when it comes to excel and such so bear with me
right basically i have 2 sheets
both have just over 5 thousand items.
column a contains a code
column b contains manufacturer
basically one is the old system/website
and the second is the new system/website
so apparently 2 things have happened. since the old system new items have been added to the new list and also not everything imported to the new system correctly so this is going to have to work both ways
i need a way of creating TWO new lists in a new sheet. One will contain items which are on sheet 1 and not sheet 2
and vice versa. sounds simple enough but i have no idea how to go about this.
how would i do this ?
cheers
alec
First off I have limited knowledge of excel, but i'll have a crack all the same:D
What I would do would to put a vlookup formula in there,
=vlookup(old!a2,new!$1:$5000,2,false)
old!a2 this being the first code to lookup in the "old" system
new!$1:$5000 this being where to retrieve the data from, i.e. new system between codes 1 and 5000.
2 this is what column to return with, so in this case manufacturer, it has to be a numerical value so column a=1, b=2, c=3 e.t.c
false false finds an exact match to old!a2, rather than true which is the closest match
Now this would search for old code 1 in new sheet and return with the manufacturer name if found and if not return with N/A, you would then filter the N/A's to get the code that are on 1 sheet and not the other.
Sorry if this doesnt help much but I tried :p
Took the adice i've a very smart chap and just plopped the whole lot in access 2007 and used queries. all sorted now :)
thanks for trying thou!
ta
alec
Hehe =p
i cant believe i didnt think to do it that way in the first place! *pulls face*
Its well efficient, working with several tables all containing upto 13k items without a single bit of lag or issue :)
right, the big one tomorrow - gotta start putting stuff thats missing on the company website! hopefully goes nice and painlessly like today.
thanks again for your help people :)
