Excel help please
3 Nov 2003
Lancashire
Hi
I'm a complete excel novice and could do with a little help if you can. as you can see pic its a really simple document.
The formula im after is to go in the 'Variance' field, I want it so that if there is no amount in the 'Actual' field, it displays 0. So in the pic above, the 1st 2 amounts are correct, bu tthe 3rd down should show £0 not -£2000
The formula in there at the moment is =SUM(E4)-D4
You could do it with an IF Statement
eg.. =IF(d4=0,0,(E4-D4))
What this does is say, if d4 is zero, put in a zero, if it isn't, do the formula.
Hope that helps
How about:
=IF(D2>0, C2-D2, 0)
Where C2 = amount field, D2 = actual field
edit: beat :(
Cheers guys, 1st one didnt work for some reason, but second did.
=IF(E4>0, D4-E4, 0)
works a treat. thanks again :)
=IF(E4>0, D4-E4, 0)
Odd as I did test it. Maybe the Amount cell wasn't completely blank (e.g. you may have used space to clear the contents, and the cell then becomes a string)
Not to worry as the other solution did the job fine anyway. :)
