Excel help please.
8 Mar 2004
Leicestershire
Evening all,
Im after bsome excel help if possible.
Picture this, i have a workbook with 3 sheets as follows.
Sheet 1 (PC Names) = List of computer names
Sheet 2 (Success) = List of computernames
Sheet 3 (Failures) = List of computer names
What i want to do is on sheet 1 check if computername exists in sheet 2 and if so colour it green and if it exists in sheet 3 colour it red.
I've had a look at conditional formatting but i dont hink it will do what i want.
Basically i've a script which is processing a list of 3000 pc's and resetting the local admin password then presenting me with a 2 text files one for success and one for failures which im them copying into excel.
Hope this makes sense?
Any thoughts.?
Excel dosen't allow references to other sheets in conditional formatting, so a cell in the current sheet has to be be used as a check.
example
Sheet 1, A1:A10 contains your list of names
Sheet 2, A1:A10 contains list of successes
Sheet 3, A1:A10 contains list of failures
formula in B1 =MATCH(A1,Sheet2!A$1:A$10,0)
repeat formula for B2 to B10
Column B flags successes
formula in C1 =MATCH(A1,Sheet3!A$1:A$10,0)
repeat formula for C2 to C10
Column C flags failures
Conditional formatting for A1
Condition 1
Formula is, =B1>0
set format to green
Condition 2
Formula is, =C1>0
set format to red
Copy and special paste formats into the rest of column A without overwriting existing data.
