Excel Help
4 Jun 2007
South Wales
Hi guys,
I'm setting up a spreadsheet to work out my work hours, but trying to base it on my clock card at work. Reason being is that the clock machine went fubar on monday and although payroll have said they'll work it out, I don't trust them as far as I can throw them, so I want to make this sheet so I can give that to them at the end of the week.
Layout is basically
|Day|In|Out|Total|Running Total|
|___|__|___|____|___________|
The problem is that when the running total passes 24 hours it start again at 00:00, now I know this is because it is working it out based on a day of 24 hours, but I want it to go up to 40 hours and beyond, is there any way around this?
TIA
Try formatting the Running Total column as a "number". That should remove the "time" format.
ie select cells - right mouse click and select "Format Cells..." - on the Number tab choose "Number" (second from top) - choose number of decimal places - click ok - done
I've uploaded an example.
Slightly different to the others' suggestions but that's always the way with excel!
http://www.2shared.com/document/Q1mDzlh2/clocking.html
Looks like:
Day In Out Total (hrs) Running Total (hrs)
01/01/2009 08:00 18:43 10:43 10.72
02/01/2009 07:58 12:43 04:45 15.47
Formula:
39814 0.333333333333333 0.779861111111111 =C2-B2 =D2*24
39815 0.331944444444444 0.529861111111111 =C3-B3 =E2+D3*24
Formatting:
dd/mm/yyyy hh:mm hh:mm hh:mm Number
Total is done on hourly basis with minutes as decimal
