Excel Help
Total cost is what i need to sort, e.g. So that it displays the top 5 values in a range. Is there a forumla that does this?
Should i just the sort and filter tab and sort by the smallest to largest? And use data from top 5?
The reason i need to do this is to creat a pie chart of the top 5 greatest values, to be inclued in my pie chart.
Sorry if this isnt helpfull :(
The problem is you need 5 functions as you need to fill 5 cells and somehow make all the functions work together otherwise the will display the same solution.
Create a pie chart based on the top 5 cells, then whenever you paste new data in, sort and the chart will update automatically.
This is easy.
Set an area aside for the pie chart data.
In cell 1 put:
=LARGE(costdata,1)
[where 'costdata' is the area of data containing the costs you want to five the top X of]
Then cell 2 put:
=LARGE(costdata,2)
As many times as you want.
Then select the area where you have put the 'LARGE' functions and create a pie chart.
If total cost is in column A, then:
B1 =LARGE(A:A, 1) ---> Alternatively you could just use =MAX(A:A)
B2 =LARGE(A:A, 2)
B3 =LARGE(A:A, 3)
B4 =LARGE(A:A, 4)
B5 =LARGE(A:A, 5)
/edit, beaten - damn doing real work in between reading and posting.
