Excel help
6 Jan 2006
Newcastle upon Tyne
Is there anyway I can compile a list based on an IF statment?
Ive got a list of clients and I want to pull out onto a seperate worksheet any that contain "ltd" or "limited"
If having 2 variables is a problem I can change all the ltd's to limited with a find and replace.
Thanks
I'd probably do this:
...then on the other sheet do =IF(Sheet1!B1=1,Sheet1!A1,""). Though there's probably an easier / cleverer way of doing it.
There will be gaps in the list initially but you can just sort it.
Use the built-in filter system. You can have it copy all records with "limited" or "ltd" in to a separate sheet without affecting the source list, and it'll take about 2 minutes to set up the first time you do it.
Look up "advanced filter" in the excel help for a step-by-step, including the use of wildcards. If you need more than that to go on, I can probably give it a go, but TBH with those keywords (excel advanced filter) and some googling you should be golden.
Let us know how you get on.
Wow that works perfectly thanks! Never used an advanced filter before but it was pretty easy to do once I worked out you had to put *limited* in the criteria.
The only bit I cant seem to work out is whether its possible to put *limited* OR *ltd*
Any ideas? If not I can just find and replace and Ltd's
EDIT - Ive cracked it! You can add another criteria underneath the first one and just change the criteria range to include the new addition.
