Excel help
26 Feb 2004
Hampshire, England.
Hi guys,
I've been working on spreadsheet which I've been sent from work and I'm having a few problems with what I type... basically every time I type 'and' it is automatically replaced with 'N/A'. I'm guessing its something that's been set in the sheet but I can't work out how you get rid of it :(
Any ideas?
Change the cell properties to be text. It thinks you're trying to enter an 'AND' formula.
I think I know what you mean mate, but I don't think its a formula issue - it doesn't look like the normal "#N/A!" it appears like some kind of 'find and replace' has been set...
Ah right. If Excel 2007 or newer, go to the data tab in the ribbon and check data validation. Someone might have set validation to return N/A unless an approved entry is made in the cell.
I'm using 2003 and I think the file was created in 2003...
Cheers mate!
