- 18 Jul 2012
Hi guys,
Could do with a little bit of help on a project i'm working on.
I have a spreadsheet (lets call it spreadsheet 1) that lists client details and one field is vehicle reg number. This spreadsheet is from the previous month.
I have another spreadsheet that contains the same information but it is selected using different search criteria (spreadsheet 2).
What I need to do is write a macro to remove any records that appear in both spreadsheet 1 + 2 from spreadsheet 1.
I have this working but I would like to streamline it. Currently it copies a list of reg numbers from spreadsheet 2 into spreadsheet 1 and then runs the following code:
I then delete all rows where the value in P = 123.
This works, and is fine but the problem is I would have to do this for every cell in the "P" column which is a pain!
Is there a way I can "streamline" my code?
More than happy to go off and find the answer I just need somebody to point me in the right direction
Thanks for any help!
Edit: The data I am copying in can be in any order, so if a reg number in cell P4 = DJ55 6HH, this record could be in cell M370.
PHP:
For each c In Range ("m2:m500")
If c.value = Range ("p3") Then
c.value = 123
End If
Next
If c.value = Range ("p4") Then
c.value = 123
End If
Next
