Excel Help
13 Oct 2008
SE London Born and Bred
I have simplified the information for this but basically I have a spreadsheet with the following in
Sheet 1
Code Pick Name
1,X,Andy
1,,Bob
1,,Colin
1,,Dave
2,,Edward
2,X,Frank
1,,George
2,,Harry
3,X,Ian
3,,James
3,,Kevin
Entered as csv
There are dozens of lines of codes (1 through 5) each line with a different name. So code 1 has about 15 names, code 2 has about 10, code 3 about 12 etc etc.
Each week I would like to go down the list and insert an X into column B to pick the person for each code.
Sheet 2
Code 1 = Name
Code 2 = Name
Code 3 = Name
I would like sheet 2 to autofil the Name for each code by querying sheet 1. So it would have to look down column A for a 1 for code 1, then check column
B for an X, if there is an X, put the name in column C in the cell in sheet 2. If not check the next row. Rinse repeat for all 5 codes until I have all 5 Codes autofilled in sheet 2
Hope this makes sense and any help appreciated.
Thanks
Screenshot:
Formula (this is an array formula so you need to enter it by pressing Ctrl+Shift+Enter):
Code:
=VLOOKUP($E2&"X",CHOOSE({1,2},A:A&B:B,C:C),2,0)
Technique from:
http://chandoo.org/wp/2014/10/28/multi-condition-vlookup/
I'm sure there are a dozen ways to do this but this was the first that came to mind :)
