- 29 Jun 2004
As per title.
How do I display zeros? E.g 001, 002, 003 etc
Thanks
Thanks
Format the cell as text or prefix your numbers with ' - e.g. '001 '002 etc.
The latter would leave you with an annoying ' though wouldn't it? Text cell formatting should work fine though, and you can still use the values in formulae.
Sorry to revive this super old thread, but I googled the problem and this is the first hit. Devo's suggestion works, but it doesn't allow you to enter the first few manually (e.g., 001, 002, 003, etc) and then select the cells, hit the button at the lower right of the bottom selected cell and drag down to the rest of that column to make it read, '004, 005, 006', etc after that.
Is there a way to do that? It just turns everything to '001, 001, 001', etc.
Make the second cell the following number (002), highlight both and then use the corner to drag down.
