excel if in a month, add to a total
1 Jul 2007
Had a go at google but not sure if my spreed sheet needs to be better formatted to begin with.
I would like a formulae that would take the date from "invoice date" column and if it's in the month (eg october) use the figure from "invoice amount" column and total it. Any ideas?
=IF(month(a1)=month(today()), b1,””)
Something like that might work but I can’t test at the mo because on phone.
You can either do what Sui has suggested which would probably need an additional column and then sum all the totals at the bottom, or you can use the SUMIF formula
Assume your dates are in Column A, and your costs are in column B:
=SUMPRODUCT( (MONTH(A:A)=10) * (B:B) )
"(MONTH(A2:A6)=10)" creates an array of 1 and 0, it's 1 when the month is October
SUMPRODUCT first multiplies each value of the array created in the above step with values of the array (B2:B6), then it adds them together.
