So I have a sub (pasted below) I have started working on. It works just as I would expect when the target sheet is open, but not when it isn't. Obviously, half the point of this is not having to open it. Any ideas what I did wrong?
It's the start of a bigger macro that will copy the data found in a cell on the same row of that sheet, into another sheet that we will be using directly.
Code:
Sub ScanTrailer()
' Select the contingency data
With Workbooks("Shaw Contingency Report.xls").Sheets("BusinessContingency_Report")
.Activate
.Range("C2").Select
End With
' Variables
Dim Found As Boolean
Found = False
Dim x As String
x = "WHSE\DES\24"
Do Until IsEmpty(ActiveCell)
' Check active row for yard path
If ActiveCell.Value = x Then
Found = True
Exit Do
End If
ActiveCell.Offset(1, 0).Select
Loop
' Return found data
If Found = True Then
MsgBox ("Value found in cell " & ActiveCell.Address)
Else
MsgBox ("Value not found")
End If
End Sub
