You could mess around with parsing the times and doing calculations based on that, but it would be easier to just split each day column into two and have a 'Start Time' and 'End Time' then it would just be a straightforward sum and subtraction.
Don't know if excel will count it as hours.
You could do it one of two ways...
Firstly only enter in number of hours worked, so monday would be 8 hours (not sure if you're having lunch). Then do a total count for the week.
Secondly a little more complex, but for each day you have two separate columns for start and finish time. But not using time format so 8:00 would be 0800. Then have a hidden column on the side that subtracts the start time from the finish time to calculate the hours. Then count up the hidden columns for the total week.
This is what I was going to say, Don't even need the hidden column reallySecondly a little more complex, but for each day you have two separate columns for start and finish time. But not using time format so 8:00 would be 0800. Then have a hidden column on the side that subtracts the start time from the finish time to calculate the hours. Then count up the hidden columns for the total week.
Interactive version courtesy of Rich_L. Should explain all
I didn't see this link earlier. cheers, looks good*cough* points up at my post![]()
Yeah, I'm investigating it nowInteractive version courtesy of Rich_L. Should explain all![]()
I've tried that by changing the format of that cell, and it would show as 0,854..Perfect, i wasn't sure if excel would add up that format.
Can you change the format for the total column to just number?
]I've tried that by changing the format of that cell, and it would show as 0,854..
https://docs.google.com/spreadsheet/ccc?key=0Aljf3hJZmCQBdC1lcVotZjVWMVVWX0pFWnl4Wi1uMXc
Quite messy, But seems to do the job.
There is also probably a MUCH easier way to do this but I'm quite simple with Excel.
but I think any formula that works in excel is fine.
For me wasting all that time.
Did this a while ago if it's of any use ... just enter the start/finish time and it will do the rest
No but I can send it to your via e-mail ... message me via trust and i'll sort you out
