Excel problem - Cannot change excel options
23 Sep 2007
Hereford
I've got a user who is curruntly experiencing a strange problem with Excel in Office XP Pro 2003. The user's OS is XP Pro SP2 with current updates.
When the user opens an Excel file or a new blank workbook, if they go into Tools, Options and then try to select any of the tabs there, such as save, they get the following error message :
"Cannot access directory (location of directory)"
I've checked in the location that it points too and everything appears to be correct there. I've tried a detect & repair as well as uninstalling and re-installing Excel by itself but the problem persists. This leaves completley unistalling and re-installing the Office suite to try, which I don't really want to do as it's inconvinient for the user and it appears that this may not solve the problem anyway.
Now the research I have done suggests that it could potentially be a profile problem as we do use roaming profiles but again rebuilding the user's profile is the last thing I want to have to do. I have also read that there may be a way to get around this in the registry under "current user\software\micosoft\office\excel\options" that can be used to reset this but I cannot see anything there that would allow me to do this there.
Any help is gratefully appreciated as this has got me stumped at the moment.
Whats the folder and have you checked the perms on that folder to see if the user has change perms at min on it?
Well I managed to fix it.
Folder permissions were fine. I found the registry entry that allows you to repoint where the autosave feature goes but that didn't work, so I was left with trying to re-install office.
What a hassle that was. Couldn't re-install under the users a/c as it couldn't access a folder. It was the some with my domain admin a/c so I had to use the local admin a/c. Luckily that worked and the re-install fixed it but I was become concerned that I might have to rebuild the profile or even the pc.
