I'm having some difficulties creating a new formula by sourcing from a cell using the "IF" formula.
In column A, I have a list of repeating names, in column B I have a rank (1-10), and in column C I have points (using an IF formula to put rank 1 = 10 points, rank 2 = 9 points etc.)
Then I want to create a new formula for when "IF Column A name is _ _ _ _" "SUM Column C", so that only the relevant rows of the same name are totalled.
However, when I carry out the formula, the result will always be 0. I know the formula is pretty much correct, because if I replace Column C (where its trying to source the points value) with actual numbers instead of calculating it from Column B, then the correct totals are appearing.
I'm running Excel 2003, is this a problem with the version of Excel or a formula error?
Hope its not too confusing to understand and many thanks for any help!
