Excel Query
4 Mar 2008
Wandsworth
Hi all,
I am trying to multiply a fixed value in one cell, for example the value in sheet 1 A1 by the values in Sheet 2 A1, C1, E1, G1, I1, K1 etc, and then store the value in Sheet 1 A2, B2, C2, D2, E2, F2 etc.
I have managed to fix the formula to use A1 with the $ sign, however when I drag the formula of Sheet1$A1*Sheet2A1 across it changes the formula to Sheet1$A1*Sheet2B1 rather than Sheet1$A1*Sheet2C1 which is what I want.
Is there a way of doing this?
Thanks
Type it out manually twice, select both then drag them out. If you've got 2 with the fixed cell number excel will realise you want that cell the same in every formula you drag out.
I've tried that and it doesn't seem to work
If I select the formula containing D and F for example and drag them out it repeats F and then does H, so I get DFFH, whereas it should go DFHJ
You can use the indirect and column formulas to skip every other value.
I'll have a look in a bit
try this in sheet 1 B1:
=$A$1*INDIRECT("sheet2!R"&ROW(A1)&"C"&(COLUMN(A1)*2),FALSE)
it'll skip every other column in sheet 2 but go down with the rows [so it wont skip every other row] and can be dragged to infinity.
what it's doing is building up a cell adress of "sheet2!R1C2" kind of thing, using the ROW and COLUMN formulas to get a number for the row and column and in the case of the column multiplying it by 2 to skip every other value
i use a formula similar to this for producing graphs and reporting results based on the name of the tab, i have one standard 'template' graph and i just copy out as many as i like and rename each tab to the batch number and it'll return it on the main sheet.
