excel question
6 Mar 2008
Stoke area
Hi all,
Just wondering if it is possible to get a cell to automatically change colour depending on the numerical value inside the cell?
Using Excel 2007.
Thanks
After trawling through loads of pages I have found my answer, conditional formatting :D
Anyone any really indepth excel tutorial links for 2007??
Quite easy really. Go to a cell or cells, then click the conditional formatting button (I forget what tab it is under) then add a new rule and type the formula you want for the cell to go a different colour. So if the number is greater than 10 the cell goes red you'd want (A3>10) or something similar. :)
Google should get you a few tutorials for this.
