Excel question
16 Oct 2007
UK
Dear all,
I have a nice simple "SUMIF"
=SUMIF($B$4:$B$68,$E72,G$4:G$68)
B: Department they work
E72 = "Kitchen"
G: Hours they work
So, add up all the hours for everyone that works in the kitchen
But how do i do it, so it does the same BUT
add up all hours if they work in the kitchen AND another cell states they're permanent?
Can you do an AND function within the SUMIF's "criteria" bit?
Thank you
Sorted it!
For all future "nested sumif" searches...
The key is using a SUMPRODUCT
=SUMPRODUCT(($B$2:$B$68=$E101)*($F$2:$F$68="P"),G$2:G$68)
First criteria (ie. Department = "kitchen")
Second criteria (ie. Contract = "Permanent")
Range to sum
