Hi folks,
This is a much simplified example of something I'm working on. What i am trying to do is calculate an average in the final column of only the values that fall inside the upper and lower bounds.
For example: for 'Country 2' i would like the average of 59, 101, 103 = 87.7
I know how to do this using the averageifs function, but (as far as i can see) this only works with fixed numbers (see below). I need it to refer to the upper and lower bound cells, as the values in these cells will change.
Country 1 example: =AVERAGEIFS(B3:G3,B3:G3,">5",B3:G3,"<15") This works great but instead of ">5" and "<15" i need it to refer to the cells H3 and I3
I hope this make sense
Thanks
Thanks
