Excel Sum
7 Feb 2004
I'd really appreciate it if someone could help me out with a sum that I can paste into an excel spread sheet.
I have designed a spread sheet that you enter the quanity into each product and it gives you a total price for that number of products.
I then need it to add each individual sum and give me a total sum, this bit i can do but I then need it so that if the sum is less than £150 it adds £10 on, over this amount, nothing gets added on.
Thanks.
Using a IF function it should look something like this:
=IF(C7<150;C7+10)
where C7 is the cell that holds your total price.
Much appreciated, just noticed your reply while I typed mine out, I'd put into mine D12+0 at the end which I've obviously now realised after reading yours I don't need the +0
Thanks for that you've been a great help :D
