Excel to csv?
6 Jan 2006
Newcastle upon Tyne
I know you can go to file>save as then select format but is there anything I could do so its basically a click of a button? MAcro perhaps? If so any pointers would be really helpfull!
I know it doesnt take that long to save as a csv but Im going to be doing it on potentially hundreds of files.
Thanks, Mark
Can't you literally just record yourself saving a file as a csv. Can't imagine there'd be too much code to change.
EDIT: looks like you could, have just recorded myself in office 2007.
Code:
    ActiveWorkbook.SaveAs Filename:= _
        "C:\meh\filename.csv", _
        FileFormat:=xlCSVMSDOS, CreateBackup:=False
COuld make a few variables in the name, so its saved with the current date if u like too.
