Excel VBA help
18 Oct 2002
Maidenhead
Hi all,
Is there any way I set use VBA to validate a worksheet using named ranges.
Ie if i have a block of 4 cells from A1 to B2, what vba code would I need to say
If all cells in the named range are blank then
tell the user they're rubbish and cant fill forms in correctly
End if
Any help will be greatly appreciated.
Thanks
To expand, Im basically doing a form which will use lotus notes to send the current worksheet via email to the helpdesk. Ive built the code which will send the email with the attachement, but want it to validate the form first.
I plan to have a lot of named ranges ie firstname, surname, requiredprinters etc, and want the code to say (psuedo code)
if firstname.value="" then
msgbox "You must enter a value for First Name"
Elseif surname.value - "" then
msgbox "You must enter a value for SurName"
End if
etc. The problem is also that the named range may be more than just one cell, so it would need to say
if all cells in requiredprinters = ""
msgbox "You must enter at least one printer"
End if
Does that explain it a bit better?
you don't necessarily need any vba code to do this - you can do it all by naming a range and chosing data validation although this might be too simplistic for you.
if not give the below a go (you probably need to change it a lot)
Code:
Private Sub Worksheet_SelectionChange(ByVal Target As Range)
    Dim myRange As Range
    Set myRange = Worksheets("Sheet1").Range("A1:D5")
    myRange.Font.Bold = True
    If RangeIsEmpty(myRange) = False Then
        MsgBox "enter some data"
    End If
End Sub
Function RangeIsEmpty(ByVal SourceRange As Range) As Boolean
  RangeIsEmpty = (WorksheetFunction.CountBlank(SourceRange) = SourceRange.Count)
End Function
Hi ya,
Thanks for your help. The named range will return a value of the range ie "$A$1:$B$2". How do I get vba to look at each cell in that range, and return an error if they are all blank?
This works if any of the cells in the range are blank and gives you the message everytime you move in the worksheet. Might need some adapting so that the message doesn't get irritating.....
Code:
    Set myRange = Worksheets("Sheet1").Range("A1:B2")
    If WorksheetFunction.CountBlank(myRange) > 0 Then
        MsgBox "You must enter some data"
    End If
End Sub
the code below works if all the cells in the range are blank.....
Code:
    If RangeIsEmpty(myRange) = True Then
    End If
End Sub
End Function
hope this helps
Ta... the range I get back is "$A$1:$B$2" this doesnt work in the code above. How would I strip any $ signs out of the variable?
ok... getting there...
strInput = ThisWorkbook.Names("Printers").Value
Test:
If InStr(strInput, "$") = 0 Then
RemoveSpaces = strInput
Else
strInput = Left(strInput, InStr(strInput, "$") - 1) _
& Right(strInput, Len(strInput) - InStr(strInput, "$"))
GoTo Test
End If
That gives me =Sheet1!A1:B2
I now need to strip the = out, and split the variable in two so the first is the sheet ie anything up to the ! and the second is the range ie anything after the !. Can anyone help?
ok made it a bit nicer now:
strInput = Replace(strInput, "$", "")
strInput = Replace(strInput, "=", "")
Sheet = InStr(1, strInput, "!")
NameRangeSheet = Left(strInput, Sheet - 1)
NameRangeCells = Right(strInput, Sheet)
Test:
Else
GoTo Test
End If
I don't think I quite understand what you are trying to do but why don't you refer to the range in the code rather than trying to strip out the address of the range ?
i.e.
I define the range on my spreadsheet manually - call it test1 and then change my code so it refers to Test1....
Code:
    'Set myRange = Worksheets("Sheet1").Range("A1:B2")
    Set myRange = Worksheets("Sheet1").Range("test1")
    End If
End Sub
There are lots of ways of getting the address without having to play around with strings.....
Set myRange = Worksheets("Sheet1").Range("$A$1:$B$2") <-----works ok.
Set myRange = Range("Sheet1!$A$1:$B$2") <----- works ok.
Code:
Dim NameRangeCells As String
Dim NameRangeSheet As String
'Get the range of the named range called Printers
'Stip out the $ and = from the range
'Find the position of the !
Basically im searching a named range to check that a user has entered data in there.
I could use the CountA function if I can work out how to use it with the above.
ATM: I have a named range called Printers set up on D21:D24. The above returns the NameRangeSheet as "Sheet1" and the NameRangeCells as "D21:D24".
Currently fiddling with:
Code:
Set myRange = Worksheets(NameRangeSheet).Range(NameRangeCells)
If WorksheetFunction.CountBlankA(myRange) > 0 Then
End If
Set myRange = Range("printers") will work ??????
and then use one of the two code examples for searching the all or any of the range. You don't need any of that string editing do you ?
This appears to work... Any changes you reckon I should make??
Code:
Sub test3()
    RangeIsEmpty ("Printers")
End Sub
Function RangeIsEmpty(ByVal SourceRange As String) As Boolean
Set myRange = ActiveSheet.Range(SourceRange)
RangeIsEmpty = (WorksheetFunction.CountBlank(myRange) = myRange.Count)
If RangeIsEmpty = True Then
End If
End Function
A[L]C said:
doh
@ me
thanks
I've done things like that in the past - and I'm sure I'll continue to do them. :)
looks good although it could be trimmed down a bit - you've just got to decide where to put it otherwise the user will get a message everytime they enter a cell.
its going in to a validation sub which is triggered when they select the option from a command menu. :)
How would I create a variable which I could use that function to populate for multiple named ranges... ie
Named ranges:
Forename
Surname
Telephone_Number
Printers
Then if they have not filled in multiple sections they will get one error message at the end saying
Please fill in the following sections:
Telephone_Number
Printers.
Would this be a const or public variable or other?
Named ranges:
Forename
Surname
Telephone_Number
Printers
Telephone_Number
Printers.
I don't know if this will work but you can refer to multiple ranges at a time by doing the following.....
Range("Forename, Surname, Telephone Number").
other than that it might just be writing some code ! and setting an error message variable.... i.e.
Sub test3()
msgstring=""
If RangeIsEmpty("forename") = True Then
msgstring = "forename"
End If
If RangeIsEmpty("surname") = True Then
msgstring = msgstring + "surname"
End If
if msgstring <> "" then
msgbox "Please enter the following " & msgstring
end if
End Sub
End Function
|Thanks for your help. This all seems to work fine
Code:
'Require all variables to be defined
Option Explicit
'Declare public variables
Dim NotEntered As String
Dim ErrorCount As Integer
Public Validated As Boolean
Sub validate()
'Decalre variables
Dim n, result
'Reset variables in case this is not the first time it has been run
NotEntered = ""
ErrorCount = 0
'For each Named Range in the workbook, run the function to check if it is empty
For Each n In ActiveWorkbook.Names
    If Not Left(n.Name, 3) = "nr_" Then
        RangeIsEmpty (n.Name)
    End If
Next n
If ErrorCount = 0 Then
    result = MsgBox("All required fields populated.", vbOKOnly, "Form Validated Ok")
    Validated = True
ElseIf ErrorCount = 1 Then
    result = MsgBox("Please enter some data for the following field: " & vbCrLf & NotEntered, vbExclamation, "Missing Data")
Else
    result = MsgBox("Please enter some data for the following fields: " & vbCrLf & NotEntered, vbExclamation, "Missing Data")
End If
End Sub
'Declare variable
Dim myRange
'Set the variable to the range specified by the named range
'Count the number of blank cells in the range.  If True then there are no populated cells
'If no populated cells, set public variable to the name of the named range
    NotEntered = NotEntered & vbCrLf & SourceRange
    ErrorCount = ErrorCount + 1
End If
End Function
