Excel VBA help...
20 Oct 2002
Pateley Bridge, North Yorkshire
Hello,
Please can you help...
Thanks in advance! :)
Two Workbooks:
Book1.xls
Book2.xls
Book2.xls contains links to Book1.xls
Book1.xls contains a password to open: "abc"
I need to update the links in Book2.xls from Book1.xls without entering the password.
I've written this code however, it doesn't actaully update the links!!
Can you think where I could be going wrong?
Is it even possible?
Private Sub Workbook_Open()
Application.AskToUpdateLinks = False
Workbooks.Open Filename:="Book1.xls", Password:="abc"
Windows("Book2.xls").Activate
Calculate
Workbooks("Book1.xls").Worksheets("Sheet1").Activate
Range("A1").Select
ActiveWorkbook.Close SaveChanges:=False
ActiveWorkbook.Close SaveChanges:=True
End Sub
Try this
Workbooks.Open Filename:="book1.xls", Password:="abc"
Calculate
Workbooks("book1.xls").Close
End Sub
Hi A[L]C
I've just tried your solution at home using Excel 2007 in compatibilty mode and it's worked. So simple too!
I'll try it tomorrow at work in Excel 2003 and keep my fingers crossed.
Cheers,
BH
Worked a treat. Many Thanks again.
It's amazing how many references there are to this situation around the web, but no solutions and yet it's such a simple piece of code! Weird.
