excel woes
2 Oct 2004
N.W London
Hi,
I have a column of numbers in excel that has a space before each number inside each cell, the only way to remove the space is by clicking on the cell and then pressing backspace and then enter, but trouble is I have only 2000 cells like this, is there a formula I can use to do this automatically?
I have tried left indent etc but still didnt work..
pls help me solve this
thanks in advance..
cheers
that doesnt do it
that will only do 1 cell at a time, i need to do 2000 numbers in a lot of cells...
is it because the data has been imported?
Put the Trim command in cell A2. Drag it down and you will be able to apply that formula to all the cells in like 5 seconds.
Best solution is to get the program that produces the data to trim it before exporting it.
