Ive got an Application_Error method in my Global.asax file that looks like this:
It works fine, but the trouble is, the information that gets written to the event log is no where near as useful as the information that gets displayed on the default "Server Error in '/' Application" error page. Here is a comparison:
"Server Error in '/' Application" error page:
Event Log:
As you can see, the event log is pretty useless compared to the default error page.
Is there any way to get the detailed info on the default error page into the event log?
Code:
protected void Application_Error(Object sender, EventArgs e)
String Message = "\n\nThe Commission Menu Calculator has encountered the following error:"
+ "\n\nURL:\n " + Request.Url
+ "\n\nMessage:\n " + Server.GetLastError().Message
+ "\n\nSource:\n " + Server.GetLastError().Source
+ "\n\nHelp Link:\n " + Server.GetLastError().HelpLink
+ "\n\nStack Trace:\n" + Server.GetLastError().StackTrace;
// Create event Log if it does not exist
String LogName = "Application";
if (!EventLog.SourceExists(LogName))
EventLog.CreateEventSource(LogName, LogName);
// Insert into event log
EventLog Log = new EventLog();
Log.Source = LogName;
Log.WriteEntry(Message, EventLogEntryType.Error);
Code:
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.IndexOutOfRangeException: Index was outside the bounds of the array.
Source File: C:\Inetpub\ComCalc\ComCalc.aspx Line: 8
Event Log:
Code:
URL:
http://fsasys05/ComCalc.aspx
Message:
Exception of type System.Web.HttpUnhandledException was thrown.
Source:
System.Web
Help Link:
Stack Trace:
at System.Web.UI.Page.HandleError(Exception e)
at System.Web.UI.Page.ProcessRequestMain()
at System.Web.UI.Page.ProcessRequest()
at System.Web.UI.Page.ProcessRequest(HttpContext context)
at System.Web.CallHandlerExecutionStep.System.Web.HttpApplication+IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously).
