You only need a tiny little dot in the middle and then spread it about with a card over the full lid.
Thanks for the reply, Yes i'm aware of how much to use, it's just I got a tiny bit stuck in the areas shows in the picture when I was cleaning the heatsink.
As others have said it's not a problem so thats cool.
It isn’t a problem no but it’s easy to remove if it bothers you.
I did try with some thermal paste wipes and a small pin. Best to just leave it, as my temps seem ok
Unless paste is one of those with with some kind of electric conductivity there's no harm in having some excess.
