Exchange 2003 and clustering
28 Sep 2008
Britain
3 node cluster active / active / passive.
Two active nodes have physical drives (storage) with node one having the Quorum disk.
In cluster administrator I cannot see the disks of the second node.
Any ideas?
How do you mean sorry?
If the shared disks are not setup to be non exclusive it might mean that one node is refusing to give up the disk to the other node? if you setup the shared disk to be non exclusive then both nodes can own it at the same time.
Also, try a rescan on the node the disk wont show on.
