Exchange 2013 & SSL certificates
19 Oct 2002
Auckland, New Zealand
I'm helping a friend build a personal exchange server on Windows 2012 (he's got access to dreamspark from his university work). Due to the security inbuilt to Exchange 2013, SSL certificates are now required for full access. His AD is setup so the internal domain name is the same as his publicly owned domain.
Normally you would use a UCC cert that can do SANs however they're quite expensive and overkill for a personal server; can you define owa, oab, ecp, ews etc under a single acccess name i.e. mail.domain.com and then only require the follwoing certs?
mail.domain.com
server.domain.com
domain.com
autodiscover.domain.com
Would this work fine with the appropriate change to the virtual directories; i.e. external owa becomes https://mail.domain.com
Cheers,
Chris
Hey madman,
Nope he wants this to be a full environment for him, I'm simply helping him set it up but I've not played with exchange before.
By using a CA, his internal connections will be trusted but as this is a live environment he wants it on his phone and accessable via owa hence the need for pki certs.
They aren't "required" for full access. You can access OWA / Phone / ECP, etc without SSL from anywhere but for Outlook (RPC) you would need to either be on the same LAN or VPN in.
