Exchanging damaged money?
27 Jul 2005
The Orion Spur
I found this in the woods today while walking the dog,
You can clearly read the serial number on it, part of the note is folded in on itself.
What are the chances I can exchange it at a bank?
Edit - Result ;)
Put it in a plastic sleeve with the serial number written on it, go to a bank and ask if they can exchange it I guess. They've exchanged ripped fivers and things for me before, but that is a bit different.
Usually I think they won't replace an incomplete note, but that one has clearly rotted and hasn't been cut into two pieces... YMMV
Unlikely I would have thought:
"As a general rule, there should be physical evidence of at least half a banknote before payment can be made. If the Bank receives an application where less than half a banknote has been submitted and there is no clear evidence that the corresponding portion of the damaged banknote has been destroyed, it is unlikely that payment will be made."
Link: http://www.bankofengland.co.uk/banknotes/Pages/damaged_banknotes.aspx
I think the condition is evidence enough that the rest of the note has been destroyed.
Like I said part of the note is folded in on itself and fused together :)
I would say there's a high possibility it will get replaced as you can clearly see it has rotted, give it a go as said the worst is they can say no.
