***** Exclusive ***** Memory Deal - OCZ 6GB Reaper 1800MHz £113.99 Inc VAT
15 Feb 2006
Staffordshire
OcUK brings you ANOTHER amazing memory deal for the weekend:
OCZ 6GB 1800MHz DDR3 PC3-14400 'Reaper' Low Voltage Tri-Channel Kit.
Just £113.99 Inc VAT
The OCZ Reaper HPC PC3-14400 triple-channel memory kits are designed specifically for the Intel® Core™ i7 processor / Intel® X58 Express Chipset. Optimized for the Core i7’s triple channel mode, these new 6GB kits ensure optimal performance via an ideal combination of low voltage requirements, speed, and latency.
The Reaper HPC Series makes use of an innovative cooling solution to more effectively dissipate heat produced by high-speed memory, and offers superior cooling technology to ensure superior stability and performance over the entire life of the memory. The thermo-conductive copper heat pipe conduit is ideal for overclocking where every degree matters, ensuring that your cutting-edge investment will maintain its integrity throughout the toughest gaming missions, overclocking, or intense program applications.
Developed for enthusiasts and early-adopters, the low voltage OCZ Triple Channel solutions are the choice counterparts for leading-edge performance that won’t inhibit the functionality of Core i7 CPUs. In addition, modules are tested in matched triplets ensuring superior compatibility.
OCZ’s Triple Channel kits are 100% hand-tested for quality assurance and compatibility and feature propriety XTC (Xtreme Thermal Convection) heatspreaders for the most effective heat dissipation. Furthermore, each OCZ memory module is backed by the industry leading OCZ Lifetime Warranty and technical support for unparalleled peace of mind.
- 1800MHz DDR3
- CL 8-8-8-26 (CAS-TRCD-TRP-TRAS)
- 6GB Triple Channel Optimized kit
- Reaper HPC Heatspreader*
- Lifetime Warranty
- 1.65 Volts
- 240 Pin DIMM
This is a UK exclusive - available nowhere else in the UK.
VERY limited stock
BUY NOW to avoid disappointment at the amazing price of:
£113.99 Inc VAT.
