-=BAF=-AXE said:
Which camera is that with ?
Do you have any samples taken in the dark, or at night?
Cheers
Andy
Hi there
I took those photos this morning with one of these:-
Praktica DCZ4.4 4.2 Megapixel Digital Camera (CA-010-PK)
This entry level 4.2 megapixel camera from one of the oldest names in the photography industry. Combines a comprehensive four times digital zoom and the ability to shoot video and record sound onto SD format cards.
- 4 x digital zoom
- 2.0" TFT colour screen
- Shoots video - Movie capture and sound recording 24 frames per second
- 16Mb Internal Memory
- Electronic self timer (about 2 and 10 second delay)
- Flash - auto mode, auto mode with red eye reduction, flash off mode, flash on mode
- Connects to TV for image playback
- Pict-bridge mode for direct printing (if you have a Pict-Bridge supported printer)
- 2.8 x Optical Zoom
- System Requirements - Windows 98/98 SE/ ME/ 2000/ XP
- Dimensions - 108 x 56 x 38mm
- Weight - 140g
- Resolution - 4.2 Megapixel Camera
- Increase to 6.0 Mega pixels through interpolation mode
IN STOCK
PRICE £62.95 (£73.97 Including VAT at 17.5%)
BUY NOW!
Now bear in mind I aint no photographer, in fact I am pretty useless. I had the camera set to 4 Megapixels as that is its native resolution in super fine mode. The only next setting up is 6 megapixel interpolated resolution.
For the price the quality is extremely good and the camera seems quite resistant to shake as well as I can't keep my hands steady but these shots came out well. The pictures have been reduced in size too 1024x768 resolution for size/bandwidth issues.
The only slight downfall of this camera is its 16MB memory size which does not last long when using high quality settings but the camera does have an SD slot and considering how cheap SD is these days its no longer an issue.
I think for the price and the quality these cameras produce as you can see they are cracking deals.
