Overclockers UK are proud to announce a launch exclusive on the Zotac Steam Machine.
Zotac ZBOX SN970-P NEN Steam Machine with Steam Controller @ £799.99 inc VAT
NEN is not simply a PC turned Steam Machine. It is engineered from the ground up to game with the mechanics of the PC imbued with the genetics of console to be the most powerful small form Steam Machine. Game like a PC with your keyboard and mouse or play like a console with the all new bundled Steam Controller.
Size, sound, acoustics, and lighting are all very important for a system that will anchor in the home entertainment center. ZOTAC engineers were able to maintain a height of two inches to ensure it fits neatly into the entertainment center while still outfitting dual radial coolers for maximum cooling performance at whisper quiet levels and the ability to disable the power on LED so it will be just you and the game. Power on to a whole new way to play with SteamOS. Access thousands of games* and connect with millions of gamers*.
Specification:
- Processor: Intel Core i5-6400T (quad-core, 2.2 GHz, up to 2.8 GHz)
- Chipset: Intel 100 Series, NVIDIA
- System Memory: 8GB(Max 16GB)
- Graphics: NVIDIA GeForce GTX 960
- Video Output: 4 HDMI2.0 (Up to 4K @ 60Hz, NVIDIA Surround of multi-display not support by SteamOS)
- 1TB 2.5“ SATA hard drive
- 1 x M.2 SATA SSD slot
- Card Reader: SD/SDHC/SDXC UHS-II
- Audio: Microphone, Headphone
- 2 x USB 3.0
- 1 x USB 3.0 Type-C
- 1 x USB 3.0 (From SD Combo)
- 2x USB 2.0
- Dual Gigabit LAN
- 1 x WiFI SMA connetor
- 802.11ac/b/g/n
- Bluetooth 4.0
- CIR Infrared Port: Yes
- Kensington Lock: Yes
- LED Indicators: Power, HDD, WiFi
- Power Supply: AC Adapter O/P: DC 19.5V/180W
- Cooling system: Fan + Heatsink
- ZBOX Dimensions: 210mm x 203mm x 62.2mm
- 1 x Steam Controller
- 1 x WiFi antenna
- 1 x AC Adapter
- 1 x power cord
- 1 x warranty card
- 1 x user manual
- 1 x quick install guide
- 1 x USB drive with O/S driver
- 1 x driver disc
Only £799.99 inc VAT.
ORDER NOW
Specification:
- 2 x USB 3.0
- 2x USB 2.0
- Dual Gigabit LAN
- 802.11ac/b/g/n
- Bluetooth 4.0
- 1 x WiFi antenna
- 1 x AC Adapter
- 1 x power cord
- 1 x warranty card
- 1 x user manual
- 1 x driver disc
ORDER NOW
