*** EXCLUSIVE TO OcUK *** EpicGear!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey.
OcUK has secured the exclusive rights to a new high end gaming brand called EpicGear. They are offering the first ever hybrid Optical and Laser mouse in one and a range of mouse pads developed for this mouse in a range of sizes so there is a pad for everyones needs.
In the coming months EpicGear have a bigger range of products, including mechanical keyboards so keep your eyes peeled.
EpicGear Meduza HDST Dual Sensor 6030 DPI Gaming Mouse @ £54.98 inc VAT
Meduza is equipped with not one, but two sensors, one being laser and the other being optical. EpicGear has managed to combine the advantages of the two types of sensor onto one platform, thus providing users with lightening fast laser speed, up to 6030 DPI, and extremely stable optical precision (jitter free). Meduza is ideal for all types of games and any sensor preference. Simply choose the desired type of sensing mode on the back of the mouse between - Laser, Optical or HDST.
Co-developed by pro-gamers, every line, every curve and every concave on the Meduza is thoroughly studied and analyzd for the one purpose of extreme support and comfort for even the most hardcore gamers after long hours of play time.
- Three switchable sensor modes: Laser, Optical and HDST (Laser + Optical)
- Advanced Algorithum Logic Technology to restrain common problems like Jitter, Skip and Drift
- Optical mode: Up to 3200 DPI (four modes)
- HDST Mode: up to 4800 DPI (four modes)
- Laser Mode: up to 6030 DPI (four modes)
- 1mm Lift off Distance
- Tracking Speed of up to 200 IPS
- Acceleration Speed of up to 30G
- Longevirt Gaming Keys of 10 million clicks
- On-the-fly DPI change
- 7 buttons, 6 fully programmable
- 5 Gaming profiles with customisable LED Colour
- 15 Sets of Customisable Long Macros
- ARM 32 bit Cortex M3 CPU
- Onboard Memory of 128KB
- Independent X/Y Axle Change via GUI Laser Mode
- Supports Driverless Plug and Plug
- Angle snapping support with Laser Mode
- Auto Power Saving on/off via GUI
- Ultra swift Big Teflon Feet
- X-Braided Cable for Durability
- Ferrite Bead Cable for Durability
- USB2.0 Full Speed: 1000Hz Report Rate
- 2-Meter Cable
- 2 Year Warranty
Only £54.98 inc VAT.
ORDER NOW
EpicGear Hybrid Gaming Surface - Small @ £10.99 inc VAT
Epic Gear Gaming Mousepad - Hybrid Pad Specifically Designed for the HDST Gaming Mice.
- Dimensions: 292 x 208 x 3mm
- Composite Fabric
Only £10.99 inc VAT.
ORDER NOW
EpicGear Hybrid Gaming Surface - Medium @ £15.98 inc VAT
- Dimensions: 350 x 250 x 3mm
- Composite Fabric
Only £15.98 inc VAT.
ORDER NOW
EpicGear Hybrid Gaming Surface - Large @ £19.99 inc VAT
- Dimensions: 420 x 300 x 3mm
- Composite Fabric
Only £19.99 inc VAT.
ORDER NOW
that mouse is sexy never really had the urge to spend that much on a mouse but i guess if i did i would never buy a cheap mouse again
had a quick scan thru the review, mouse looks decent wether the price is appropriate or not remains to be seen after some user feedback.
The mouse pad and from the description of the sheen in the review seems to be pretty much the same as a boogiebug
