I only wash my skin with water and since i've done that i've not got any spots. I use a bit of moisturiser now and again but i was wondering if wetting my face and using a cotton bud will get rid of the few blackheads i have on my nose.
All I'm saying is don't try and scrape blackheads out with the edge of a knife. It doesn't work well.
Damn, that was my second option.
I know of those biore pore strip things but they are fairly expensive for what seems to be glorified celotape.
Apply Mustard and wipe away with sandpaper. Works a treat!
In the morning, if my face is a little puffy, I'll put on an ice pack while doing my stomach crunches. I can do a thousand now. After I remove the ice pack I use a deep pore cleanser lotion. In the shower I use a water activated gel cleanser, then a honey almond body scrub, and on the face an exfoliating gel scrub. Then I apply an herb-mint facial masque which I leave on for 10 minutes while I prepare the rest of my routine. I always use an after shave lotion with little or no alcohol, because alcohol dries your face out and makes you look older. Then moisturizer, then an anti-aging eye balm followed by a final moisturizing protective lotion.
