expandable menus?
19 Oct 2002
hi guys...
i would search for this but i have no idea what it would be called...
i want to create a menu (a standard vertical menu) where if you click on one of the links the menu kindof splits and the sub menu emerges between the two...
so basically by default it is like this:
menu item 1
menu item 2
menu item 3
menu item 4
and if you clicked menu item 2, there would be a smooth transition to this:
menu item 1
menu item 2
- sub 1
- sub 2
- sub 3
menu item 3
menu item 4
you know what i mean? any advice or links to resources about this would be most appreciated :)
my advice is to do a few javascript tutorials, download the latest version of jquery, read the documentation and do it that way - you can't expect to be able to pull things like that apart and do them straight away with very little knowledge.
also, try using that menu without javascript enabled. the page doesn't even load. it's all very well and good having nice interface elements like that but some people can't use them - do they get to see your site?
seriously, do tutorials or read the rhino book
