- 28 Dec 2017
- Beds
So this gets mentioned a lot as a potential benefit of discrete component AIOs over manufactured, sealed liquid coolers. But generally followed up with "but it's not recommended to actually expand this loop as the pump isn't very powerful".
So has anyone actually done it? How far would you go? Would you add a second radiator? How about a GPU block? Aside from nicer components and the ability to disassemble, clean and refill, is an AIO still not that flexible?
I have a bequiet! Silent Loop 360 and I want to repurpose the radiator as I have a better block and pump. Could I use the CPU block/pump combo in another build with a GPU?
I've seen virtually no one do this so I'm sceptical.
