**EXPANSION OF CRUCIAL TACTICAL TRACER RANGE & PRICE DROPS!!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We've expanded our range of Crucial Ballistix Tracer memory and also lowered the pricing on existing kits:-
Crucial Ballistix Tactical Tracer 16GB (2x8GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLT2CP8G3D1608DT2TXRGCEU) (Red & Green Activity LEDs) **WORLD FIRST** @ £99.95 inc VAT
Crucial is all about the win—and our complete line of Crucial Ballistix performance memory is proof of that commitment. Whether you're a casual enthusiast or hardcore gamer, the expanded Ballistix line delivers a choice of performance memory that meets your need for speed.<br /><br />
Are you ready to shed some light on your computer?
Play with even more bling — customized by you. The Ballistix Smart Tracer features activity-indicating LEDs on the top edge and ground-effect LEDs along the bottom.<br /><br />
These Smart Tracer modules are available in either Blue/Orange or Red/Green LED color combinations that you can manipulate in real time, switching up the color options. In addition, select from four different LED patterns, adjust brightness, or turn the LEDs on/off. All of this can be done on-the-fly! Turn on the lights — and turn up your performance — with Ballistix Smart Tracer memory.
Add to it the downloadable MOD utility, and you get the real-time temperature monitoring — and more!
<br /><br />
Features:-<br />
- Black PCB<br />
- Black high performance CAMO ALU heatspreaders<br />
- Ultimate performance memory<br />
- Activity LED's (RED / GREEN)<br />
- Temperature Probe<br />
- Crucial MOD software compatible<br />
- Each two module set is tested at 1600MHz<br />
- Tactical heat spreader for performance<br />
- Packaged together immediately following system test<br />
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 8-8-8-24 on Intel DDR3-based motherboards.<br />
- SPD programmed at: JEDEC standard 9-9-9-24 values at 1333MHz.<br />
- XMP 8-8-8-24 values at 1600MHz, 1.50V<br />
- 16384 Megabytes of DDR3 memory<br />
- Two matched 8GB modules<br />
- 100% tested at 1600MHz in Intel based motherboards<br />
- Supports Intel Extreme Memory Profiles (XMP)<br />
- Lifetime Warranty<br />
- Sandybridge compatible<br />
- Bulldozer compatible<br /><br />
Only £99.95 inc VAT.
ORDER NOW
Crucial Ballistix Tactical Tracer 16GB (2x8GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLT2CP8G3D1608DT2TXOBCEU) (Orange & Blue Activity LEDs) **WORLD FIRST** @ £99.95 inc VAT
<br /><br />
Features:-<br />
- Black PCB<br />
- Activity LED's (ORANGE / BLUE)<br />
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLT2CP4G3D1608DT2TXRGCEU) (Red & Green Activity LEDs) **WORLD FIRST** @ £49.99 inc VAT
<br /><br />
Features:-<br />
- Black PCB<br />
- 8192 Megabytes of DDR3 memory<br />
- Two matched 4GB modules<br />
Was [£59.99] Inc. VAT
Only £49.99 inc VAT.
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel Kit (BLT2CP4G3D1608DT2TXOBCEU) (Orange & Blue Activity LEDs) **WORLD FIRST** @ £49.99 inc VAT
<br /><br />
Features:-<br />
- Black PCB<br />
- Activity LED's (ORANGE & BLUE)<br />
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (BLT2CP4G3D1869DT2TXRGCEU) (Red & Green Activity LEDs) **WORLD FIRST** @ £49.99 inc VAT
<br /><br />
Features:-<br />
- Black PCB<br />
- Each two module set is tested at 1866MHz<br />
- Tested together at 1600MHz, Vdimm = 1.50V, at latency settings of 9-9-9-24 on Intel DDR3-based motherboards.<br />
- XMP 9-9-9-24 values at 1866MHz, 1.50V<br />
ORDER NOW
Crucial Ballistix Tactical Tracer 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Kit (BLT2CP4G3D1869DT2TXOBCEU) (Orange & Blue Activity LEDs) **WORLD FIRST** @ £49.99 inc VAT
<br /><br />
Features:-<br />
- Black PCB<br />
ORDER NOW
Also note that the Ballistix Tracer is also faster than most competitors memory as they use more aggressive memory timings to eek our a little extra performance. :)
I was tempted to get the 1866MHz before I got my Samsung Greens, they are a pretty good price for their specs and the LED's look great.
