Arkanoid said:I'm not at my PC now so cant get any detailed info.
My new system
Core 2 Duo 6600
EVGA Nforce 680i
BFG 8800GTX
Only getting around 8k on 3dmark06 Basic 1280x1024 however from what I read I should be getting more like 10k.
Any ideas?
I got 11170 at stock speed with the [email protected]. Must be drivers or a setting or two somewhere.Arkanoid said:I'm not at my PC now so cant get any detailed info.
My new system
Core 2 Duo 6600
EVGA Nforce 680i
BFG 8800GTX
Any ideas?
Boogle said:You should also run 3D Mark at 1024x768, not 1280x1024. Will not only give you a higher score, but can be directly compared to other's scores.
06 runs in 1280x1024 by default, whats the point in invalidating the score? Surely the point for the OP is to know if all is running correctly, in the ball park?Boogle said:You should also run 3D Mark at 1024x768, not 1280x1024. Will not only give you a higher score, but can be directly compared to other's scores.
