Expensive HP Ink Carts! Help
30 Sep 2008
Ok so my parents HP Deskjet F380 has ran out of black ink. They brought the expensive one's from a shop but now they need a replacement.
I promised them some cheap one's from the internet as i ordered a shed loads for my old Epson (they were 90p each!). Now ive had a look on google and the cheapest i can find for black is £6.99 (free delivery)....i was like 'oh noes wtf!'
..so if anyone knows of (really) cheap HP ink cart for this model, then speak now you'l be a star!
the reason is your replace the ink head as you replace the cart on hp,, on epson you just changing a ink tank in simple terms
thats cheap at £6.99 u wont get 90p ones,,
good luck
